My PC can't go at 20 Mbps
- My PC can't go at 20 Mbps
- « Previous
- 1
- 2
- Next »
Re: My PC can't go at 20 Mbps
23-12-2014 8:34 AM
HPsause,
I will try running it Malwarebytes in safe mode and will remove and reinstall Avast.
If that fails a friend who knows more than me visiting in the new year.
Thanks,
Wuz
Thanks,
Wuz
23-12-2014 9:23 AM
I would remove Avast and install something like Microsoft Security Essentials, but only after a thorough malware scan.
If Avast is compromised/corrupt (though other AV products are much worse in this regard IMHO) the cause may be carried over into a reinstall.
23-12-2014 1:39 PM
HPsause,
I ran Malwarebytes under safe mode with networking. Nothing found. I uninstalled Avast and reinstalled. it but it made no difference.
As there was no difference I will try replacing with MSE and see if that helps. I will do it later as I better go out and do the Xmas shopping.
Wuz
Wuz
23-12-2014 2:45 PM
It could be anything, you'll need an expert to investigate hands-on. Just that those are the most common in my experience.
- « Previous
- 1
- 2
- Next »
