My Netgear router goes in the bin after Digital POTS switchover?
disfroot
Re: My Netgear router goes in the bin after Digital POTS switchover?
@MisterW wrote:
From Dec 2025, you'll now also need a working internet connection to report a life-threatening medical condition if you have no mobile access.
I thought the Dec 2025 date had been paused.
source?
As late as Jun 2022 Ofcom still mention Dec 2025
https://www.ofcom.org.uk/__data/assets/pdf_file/0028/238555/telephony-USO-statement.pdf
shutter
Fixes: 67
@disfroot
I have sent you a P.M.
Protech
Fixes: 7
@disfroot
The pause to the rollout is discussed here
https://www.ispreview.co.uk/index.php/2022/03/isp-bt-pauses-uk-digital-voice-rollout-after-consumer-...
Also the issues are covered and the BT response to them.
You can check out but you can never leave ( easily)
disfroot
@Protech
thanks. That's BT pausing Digital Voice early trials, not Openreach announcing a change to the December 2025 turn-off.
Are we stilll playing the 'Openreach are not BT' game?
