My Dreem Computer spec would be!
- My Dreem Computer spec would be!
08-09-2008 6:03 AM
I will be using the Computer for Graphics that is Photoshop, GIF Animator, Paint Shop and anumber of other Programs as well. I will all sow be using the Computer for Video editing, Photography, etc.
The specification that I am wanting to get is:
Beige atx tower case.
Motherboard - Which one?
CPU: AMD 2 core.
Memory: 8GB Ram.
Graphics Card - Which one?
Fax Modem 56 KB For Back up, Main Modem is NTL Cable Modem.
DVD RW + & -
80GB HD for the SO and 1TB HD for File storage.
OS: XP Home Edition what I have already.
I want a New TFT Monitor 17" what is HD, I don't want it any bigger.
Everything else I have already
Re: My Dreem Computer spec would be!
08-09-2008 7:31 AM
08-09-2008 7:38 AM
08-09-2008 7:43 AM
08-09-2008 7:48 AM
08-09-2008 8:07 AM
Quote from: Midnight I want a New TFT Monitor 17"...
Yay!
08-09-2008 8:39 AM
[Edit]
Thanks adiewoo I will get a copy of Microsoft Windows XP Pro for the new Box!
08-09-2008 9:43 AM
Get yourself a 42" LCD 1080P television and put it on your desk. Plug your computer into that and it would be ideal for your website testing
08-09-2008 9:51 AM
Might be worth checking for driver updates for your current monitor to see if it goes up to (or higher) than 1280x1024 - it could save you some cash.
08-09-2008 9:54 AM
It might be worth checking out the performance/cost difference for your applications including the costs of the motherboard
One thing to consider is the noise and heat generation. I selected quiet and cool components with a well ventilated case and haven't regretted it.
08-09-2008 9:56 AM
08-09-2008 10:28 AM
James_H & pierre My Monitor resolution with a 17" TFT monitor is:
1024 x 768 - Normal setting
1280 x 1024 - Yes it can do but the text is to smol for me
1920 x 1200 - Max Size
The monitor is a Viglen TFT Monitor
08-09-2008 10:42 AM
If you have a 17" monitor and you put 1024 lines on it, the text will be a certain size.
If you only put 768 lines on it, the text will appear larger.
If you put more lines on it, the text will appear smaller.
The text displayed is a set number of lines tall, so the only way to have more lines without reducing the apparent size of the text is to have a larger monitor.
Obviously, a larger monitor will cost more though.
If reading the text is a problem for you, its pretty difficult to strike a balance between image quality and text size.
It you have more lines, the images will appear smoother, but the text which is a fixed number of lines will appear smaller.
A larger monitor with the same number of lines effectively is making the size of the line larger, so you get back to an apparent lower quality (greater pixellation, loss of smoothness)
Increasing the number of lines to smooth the picture will result in the text reducing in size again.
You see the problem?
Perhaps a larger monitor, with accessibility tools to increase the test sizes might work, but you are a better expert on this than me.
08-09-2008 10:43 AM
Can you make the text bigger? I do this in Firefox using CTRL and + (the plus sign).
08-09-2008 10:54 AM
Quote from: Midnight Oldjim yes it is the cost.
You will need a 64bit processor to go with your 8GB RAM and 64bit Windows....
