Mustek scanner hanging
- Mustek scanner hanging
27-09-2012 3:59 PM
Hi folks - I have a problem with my bearpaw scanner. Up until today it worked fine. Then after a couple of scans it hangs up. I have tries re-installing the drivers but it doeas the same thing. I am wondering if the scanner is on the way out. Any ideas?
3 REPLIES 3
Re: Mustek scanner hanging
27-09-2012 6:58 PM
Is this a proper flat bed scanner?
28-09-2012 11:25 AM
It is a proper flat bed scanner made by Mustek
29-09-2012 12:30 AM
I'd expect a scanner to fail mechanically or to get a light bulb etc failure.
My scanner came out of a skip 5+ years ago - and it's still working.
Because it's plugged into a Linux machine, it doesn't need drivers (as such) to make it work.
Peculiar yours works for a couple of runs before seizing up.
What happens if you reboot the scanner?
