Music Editing Software
- Re: Music Editing Software
24-10-2012 8:56 PM
Does anyone know of a software that will produce the same level of output, ( e.g. normal LOUD ) to whatever level is input into the software?
24-10-2012 9:00 PM
Have a look at this thread.
Forum Moderator and Customer
24-10-2012 9:11 PM
What I want to do is to re-record the music vids, they all come out at the same volume when played from a playlist...
24-10-2012 9:37 PM
24-10-2012 9:56 PM
If on DVD, are they protected? You wont be able to grab and edit a video file without some palaver.
If they are grabable files then a video editor of some sort should be able to normalize the levels. But you'd have to burn the files back to DVD.
24-10-2012 11:04 PM
The tracks are all on the HDD, not dvd or cd rom... so no problem with re-burning.
I have a couple of video editor progs (avidemux and videopad editor) but they produce the sound the same volume as it was orignal...
What I am looking for is something, where I can load a "Playlist" , then re-record them, with a pre-set constant output volume, all in one go...
24-10-2012 11:42 PM
Sounds like that's your best option to me. Otherwise you'll be doing them all one by one before burning...
You may find your burning software already has this?
edit - digital recordings should produce no hiss.
Its definitely do-able. Just a question of doing it without expensive software!
25-10-2012 12:24 AM
25-10-2012 9:28 AM
I have just acquired some software.... that "may" do the job.... will have a play with it later today, and see what happens...
