Multimeter problem..
7up
Fixes: 17
I've got a problem with a digital multimeter. It seems to be over reading voltages. 1 AA battery is supposed to be 1.5V.. 6 of mine are 1.6 and when measured in series they total up to 9.6V.
While I know there's usually a small tolerance this much can't be right? When trying to measure 3 of them (4.5V) I get over 5V. Obviously this isn't very constructive and is making some of my measurements a bit annoying.
At first I wondered if the battery was flat - IE maybe there could be a potential difference issue or a point of reference being out a bit but the low battery indicator hasn't  appeared so it can't be.
I've not got any other batteries to test it against.. only the car - which measures 13.2V.
It used to be very accurate many moons ago (I've had it 11 years).. maybe it just time to replace it but any ideas just in case?
14 REPLIES 14
198kHz
Fixes: 41
Re: Multimeter problem..
Are these alkaline or rechargeables? When I test an alkaline cell it generally reads about 1·6V open circuit.
More like 1·4 for a rechargeable just off charge, dropping to 1·3 after a few hours.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
7up
Fixes: 17
Hi
Yes, they're alkaline Energizers. That would explain it then.. maybe the meter is ok?
I was rather worried when I saw it reading 9.6V for all of them in series..
198kHz
Fixes: 41
Yup, sounds OK. Digital meters generally either work or they don't.  Wink
7up
Fixes: 17
Ok thats brilliant - not bad for an 11 year old eh! At least I can factor those readings into my calculations then.
Cheers pal
198kHz
Fixes: 41
Aye, it's nice when things keep working. I've got a BT badged Fluke which must be about 20 years old - good as new, and a Maplin one about 10.
If they've otherwise been well treated, it seems to be the LCD display which is most prone to failure. I suspect that otherwise the main reasons for early demise are rough handling or being dropped, frying by using the wrong range, or simply getting lost.
Strat
Fixes: 565
Fluke are the bee's knees but pricey. I have an ISO-Tech which serves well.
pierre_pierre
try looking here for the Voltage characteristics of different type of Cels  http://www.powerstream.com/BatteryFAQ.html
look in this section, items 3 and 4
Table of Contents
  1. Definitions
  2. Battery Parameters
  3. Primary Batteries (disposable)
        1. Leclanché Cells
        2. Alkaline Cells
        3. Mercury Oxide Cells
        4. Zinc/Air Cells
        5. Aluminum/Air Cells
        6. Lithium Cells
        7. Lithium Iron Primary
        8. Magnesium-Copper Chloride Reserve
  4. Secondary Batteries (rechargable)
        1. Lead–Acid Cells
        2. Nickel/Hydrogen Cells
        3. Nickel/Cadmium Cells
        4. Nickel/Metal Hydride Cells
        5. Sodium/Sulfur Cells
        6. Nickel/Sodium Cells
        7. Lithium Ion Cells
        8. Manganese-Titanium (Lithium) Cells
        9. Rechargeable Alkaline Manganese Cells
       10. Nickel Zinc Cells
       11. Iron Nickel Cells
       12. Iron Air Cells
       13. Iron Silver Cells
       14. Redox (Liquid Electrode) Cells
itsme
Quote from: 4C
Not true they can still go out of calibration.
Quote from: 4C
Not aware of any digital meter being fried by selecting the wrong range in more years than I care to remember working in electronics and telecommunications along side same pretty dumb technicians. Only fuses be blown when measuring high currents as the technicians have not used the correct inputs.
198kHz
Fixes: 41
Note the word 'generally'. Perhaps I should have said 'usually'.
Point taken re rarity of frying.
colintivy
Digi Multimeters usually have a very high input resistance  when on Volts DC range therefore will not load a battery to any  significant degree. It does not need much of a load to bring them down to an operating level which is what one would expect. Although I do have a digi box I still have a Pullen series 100 multimeter of 1947 vintage and its 1.5 volt U2 battery for resistance measurement, price 4d still works!!
7up
Fixes: 17
Quote from: colintivy
Wow! Thats very impressive!
@pierre: Thanks for the link Wink
Denzil
Also, car batteries are only nominally 12V. The actual open circuit voltage varies with how much charge is in it. A fully charged healthy battery could well read about 13V.
7up
Fixes: 17
I usually get 14.2 off the car lol.
Denzil
With the engine running that is normal, because the output from the alternator has to be at a higher voltage than the battery in order to force the charge back in against the flow, so to speak.. With the engine running you should see somewhere between 14.0 and 14.5V. Turn the engine off and it should go down to somewhere between 12.8V and 13.2V if the battery is fully charged.
