Multi-arch
Fixes: 8
Multi-arch
When downloading updates for mint 13 it often ends with the message,  Waited for dpkg -  -assert-multi-arch but it wasn't there.
The question is, should it be there or is it not necessary ?
If it's necessary is it just a matter sudo apt get install multi-arch or is there more to it than that. ?
Fixes: 15
Re: Multi-arch
Are you running the 64bit ver? There was an appendium for Mint 14 about needing multi-arch to install wine etc, but not in 13 that I was aware of.
Fixes: 8
Re: Multi-arch
64 bit version of Mint 13
VileReynard
Seasoned Pro
Fixes: 9
Re: Multi-arch
Me too.  Cheesy
Fixes: 15
Re: Multi-arch
You could try this:-
To enable Multiarch, open a terminal and type the following commands:
    sudo dpkg --add-architecture i386
    apt update
Fixes: 8
Re: Multi-arch
dpkg: error: unknown option --add-architecture
VileReynard
Seasoned Pro
Fixes: 9
Re: Multi-arch
http://wiki.debian.org/Multiarch/Implementation#Why_update_your_library_package_for_multiarch_suppor... includes a few reasons
Why you should do it, and
Why you shouldn't do it.  Cheesy
Fixes: 15
Re: Multi-arch
Quote from: gleneagles
Strange, that's the command to do it in M14 (which I have now switched to Mate edition of course)/
Have a look at that web page above, or just ignore the error if it is working fine.
Fixes: 8
Re: Multi-arch
Thanks.
I Think the best bet is to leave well alone as everything is working fine. Smiley
