Mp3it No Connection
valart
Mp3it No Connection
Firefox has a add on called Mp3it which allows you to down load the music from you tube to your ipod for some unknown reason it will not connect I just wondered maybe for legal reasons this as stopped.
1 REPLY
Fixes: 22
Re: Mp3it No Connection
More likely the add-on needs to be continually updated to keep up with changes (not necessarily visible ones) to the youtube website.
