Mozilla Firefox keeps freezing or crashing
- Re: Mozilla Firefox keeps freezing or crashing
21-03-2015 10:35 PM
For no obvious reason my firefox either crashes and shuts down altogether or it freezes up frequently and I have to wait some minutes till it allows me to continue what I'm doing only for it to freeze up again
I've tried backing up with Mozbackup then uninstalling to see if a fresh install will work
I've even tried deleting registry entries using iobit uninstaller before reinstalling
It seems whatever I do this problem persists
Can anyone advise?
before you say try a different browser I have my reasons for wanting to continue with firefox
21-03-2015 11:04 PM
If you have to stick to the Firefox platform, try PaleMoon, it's based on firefox and has been re-engineered to actually work reliably, even most of the plugins and addons work perfectly with PaleMoon, I've been using it for the best part of a year and the only issues I've had with it were bad addons, namely Youtube Center which just caused a massive memory leak in both Firefox and PM, but everything else has been perfect and I didn't have to re-learn everything as it's pretty much the same layout and interface as firefox...
22-03-2015 1:46 AM
Also have noticed it freezing occasionally, the mouse buttons work but the mouse won't move. This doesn't last long and I have assumed it could be the mouse battery but haven't checked that out yet.
It's not due to an underpowered PC (AMD fx6100, Radeon 6770, 16GB RAM, 60 +100GB SSDs and over 5TB of internal HDD space).
The only addons running are the English dictionary, Adblock plus and TabMixPlus.
I may give PaleMoon a whirl.
Forum Moderator and Customer
22-03-2015 2:28 AM
By the way I suggest ublock instead of ad block plus.
22-03-2015 7:52 AM
You have not made mention of scanning your PC for malware so I would suggest downloading AVG Anti Virus Free and MalwareBytes' Anti-Malware and give your machine a thorough check prior to any new installation or re-installation of your existing browser.
http://www.malwarebytes.org/
http://www.avg.com/gb-en/homepage
22-03-2015 9:18 AM
22-03-2015 9:45 AM
22-03-2015 9:58 AM
Downloaded WaterFox.
Uninstalled Firefox and restarted the PC (after all it is Windows we are dealing with).
Installed WaterFox.
Job done, and never looked back.
22-03-2015 10:23 AM
22-03-2015 1:34 PM
02-04-2015 12:57 AM
02-04-2015 7:47 AM
most crashes are due to Adons incompatibility , also have you cleared you Cache try Ccleaner .
i gave speedfox a while ago and found it made no difference to me
23-04-2015 7:33 AM
23-04-2015 12:58 PM
use waterfox instead.... its that same as fire fox but made for 64 BIT os and runs much smoother than firefox dose
23-04-2015 1:05 PM
