Mozilla Firefox - Unresponsive script error /Freexe up
juliasdream
I'm running Windows 7 and havve the latest version of Firefox
It frerequentlyt freezes up and after  while of trying the screen goes pale
Then the following error comes up
"A script on this page may be busy, or it may have stopped responding. You can stop the script now, or you can continue to see if the script will complete.
Script: file:///C:/Program%20Files/Mozilla%20Firefox/components/fuelApplication.js:221"
Options: Stop script or continue
Neither option has any effect
If it means anything to anyone I noted the following from windows event viewer:
Event data
firefox.exe
  1.9.2.3667
  b1c
  01cac4a44a9994c0
  8
  C:\Program Files\Mozilla Firefox\firefox.exe
  43d652b2-30e0-11df-b7e9-0024210f0458
  55006E006B006E006F0077006E0000000000
Binary data
In Words
0000: 006E0055 006E006B 0077006F 0000006E
0008: 0000
In Bytes
0000: 55 00 6E 00 6B 00 6E 00  U.n.k.n.
0008: 6F 00 77 00 6E 00 00 00  o.w.n...
0010: 00 00                    ..
sending the error report to microsoft had a negative result
Results  for: Microsoft Product: Windows Operating System; Version: 6.1.7600.16385; Event ID: 1002; Event Source: Application Hang;
No results were found for your query. Please see Search Help for suggestions.
I have tried uninstalling and reinstalling Firefox but that didn't help.
Any advice would be apreciated
VileReynard
Seasoned Pro
Fixes: 10
Re: Mozilla Firefox - Unresponsive script error /Freexe up
What site?
Cheesy Grin Cheesy
juliasdream
When I click on Evewnt log online help I get taken to:
http://www.microsoft.com/technet/support/ee/SearchResults.aspx?Type=1&Fallback=1&Source=Application%...
Sometimes when I do that I get some useful advice poibters from microsoft, but not this time Angry
dick:quote
Fixes: 20
I think he meant what site was the error occurring on not the M$ site.
It may be you need to install or update the JVM (sun java)
juliasdream
I don't think it's that because it happens on several sites
I can remember some
Moneysavingexpert.com
gmx.com (webmail)
saynoto0870.com
adie:quote
VileReynard
Seasoned Pro
Fixes: 10
Tried them - they all work, although Moneysavingexpert.com took forever.
I'm pretty sure none of those sites use Java - the Firefox component that is affected is fuelApplication.js
This is a piece of Javascript (no relation to Java!).
What happens if you close all Firefox Windows & then retry with a freshly started Firefox when you get this error?
juliasdream
It just happened again while trying to activate my US Dollar travellers card at Caxton.fx
https://www.caxtonfxcard.com/
I had to shut down firefox but in this case I continued using Opera instead which worked fine.
I'm back on Firefox now sending this.
Its never gone wrong using community.plus.net forums
dick:quote
VileReynard
Seasoned Pro
Fixes: 10
Do you have any add-ons?
Especially any that are not your "top ten" - if so disable them, because that caxton site is very fast loading for me...
