Moving house, Should I stay with PN or migrate to BT Infinity?
NorthEasterner
Hi all,
I a currently on Plusnet Extra fibre, I pretty much regret it now Sad as we never go up to 40GB. and not bothered about speed!
I am renting a house for a year and my it would go up by 12 months in april. I am so wondering when I move into my new build house (pernament) (not a cable area) in oct 2013, should I migrate to BT? Would there be any charges for the house move when I leave? Also I am moving to rent before april so would the fee be waived by oct 13?
Any help appreciated!
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 247
Re: Thinking of leaving then joining BT infinity option 1. Help needed
You're probably in an 18 month contract on Extra Fibre
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
NorthEasterner
Re: Moving house, Should I stay with PN or migrate to BT Infinity?
If you leave after 12 months then all charges are waived. Just speaking to an online plusnet representative
Fixes: 247
Your router charges etc are waived.. I suspect you'll need to cover 6 months of product cost e.g. 6 x 19.99
Fixes: 62
Not quite the charges are per month remaining are http://www.plus.net/info2/legal/price_guide.html#fibre Table 9
Plusnet Value Fibre £4.25 (£4 if you signed up before 14/08/2012)
Plusnet Extra Fibre £5.50
Fixes: 247
oh much cheaper, something to have in mind Wink
NorthEasterner
My Daughter use to hog up the data allowance of 40GB but now she is at university, for 3 years.  I am thinking of either taking Sky unlimited Fibre or BT infinity option 1? Can  someone recommend? which ISP have fewer internet problems?
Infinity
Seasoned Pro
One thing to throw into the equation, if you have, or will get, SKY+HD and use On Demand Catch-up, you will use a lot of GB.
Since I resurrected my SKY subs a month ago, with a very special offer from them when they rang me, I have used loads of GB !!!!!
Mostly overnight Unlimited of course. Catching up on series I have partially missed.
