Moving files issue W7
- Moving files issue W7
17-02-2010 12:30 PM
Trying to open the folder brings up the following error:
Quote C:\Users\Mav\Downloads\Folder Name is not accessible.
Access is denied.
This leads me to believe that the file is no longer there but why should it still be displayed.
W7 32bit fully updated.
Also, I find some files (and folders) fail to move with the following error:
Quote You need permission to perform this action
You require permission from the computer's administrator to make changes to this folder
<File Name>
Try Again Skip Cancel
Do this for all current items
Only Skip or Cancel have any effect.
I only have on Administrator account and I have set UAC to Never Notify.
I have downloaded the latest version of Unlocker which tells me that 'No Locking handles are found'.
The file(s) or folder(s) have the Read attribute set but I have no success in unsetting it.
Does anyone have any clues as to what is going on?
Cheers.
Forum Moderator and Customer
Re: Moving files issue W7
17-02-2010 1:47 PM
17-02-2010 2:07 PM
Was so afraid it could be down to hardware (HDD) failure.
Had this issue with XP, too, but Unlocker usually found a 'Locking handle' and I was able to resolve it or it would resolve at a reboot.
To be honest, I haven't rebooted yet and will see what happens to these files when I do later this evening.
Will report back then.
17-02-2010 2:11 PM
Dont always get the Admin one, but just press skip and it does it anyway
17-02-2010 5:20 PM
17-02-2010 6:21 PM
18-02-2010 1:19 PM
Try this. Right click on the folder, click Properties, then the Security tab. Click the Advanced button and click the Permissions tab. In the Permission entries box you should see Full control next to Administrators. Click on Administrators and then click Change Permissions. Tick the box marked "Replace all child object permissions..." then OK everything.
Hopefully if you have an odd file with different permissions that will set all the files in the folder to allow full access.
18-02-2010 4:59 PM
@Denzil So far today the issue hasn't reared its ugly head so I can't test your ssuggestion.
