Moving House
- Re: Moving House
Moving House
29-12-2015 10:57 PM
Hi Guys,
I'm moving shortly and the new house doesn't have Fibre (currently on Fibre) so can I move over and do I then have to downgrade to ADSL? does my package then get cheaper?
Were the fibre contracts 18months normally or 12?
Cheers
Rich
Cheers
Rich
3 REPLIES 3
Re: Moving House
30-12-2015 12:08 PM
Fibre packages were generally 18 month contracts. When you move house we can arrange for you to go over to ADSL2+, that shouldn't be a problem. Best bet is to give us a call so we can discuss the options with you and the costs of this, 0800 432 0200
Re: Moving House
31-12-2015 12:50 PM
Cheers Chris, will give them a call and go from there
Moved:
Re: Moving House
29-04-2016 11:02 AM
Split and moved to Feedback
