Moved NS to Plusnet - now web address not seen - gateway error - Help!
- Moved NS to Plusnet - now web address not seen - g...
07-09-2007 2:31 PM
I moved my domain name hosting this morning from 123-reg.co.uk to Plusnet. I can still access my website via IP address but now when I try the www.FGDN I get a gateway error.
All was working fine until I changed name hosts etc so guess the problem lies there. Plusnet indicates - registered and hosting.
I've configured the domain in the control panel and setup an A name for Additional DNS records (Advanced) to "www" in the left field and IP address in the right. Also done this for "mail"
Any ideas on what I'm doing wrong?
Re: Moved NS to Plusnet - now web address not seen - gateway error - Help!
07-09-2007 2:46 PM
You have told PN the domain you want to host on your account. If not then you need to raise a ticket so they can add your domain name to their DNS servers. Just pointing your domain at PNs DNS servers is not enough.
07-09-2007 3:36 PM
I used the Transfer in service to add my domain name to PN. Will I still need to raise a ticket?
07-09-2007 3:45 PM
You should have just changed the DNS on the domain @ 123reg and raised a ticket to get the domain hosted on your account. This way the domain stays with 123reg (and their low cost renewal) but is still hosted on your PN webspace.
You may not be able to stop the process now but you will need to move it out again (once it is fully setup) to 123reg and then arrange for it to be hosted only on your PN account
07-09-2007 3:52 PM
Will wait a couple of days and move it back to 123-reg. Was having other problems with mx records there.
I'm not using my PN webspace I've setup my own webserver on a Linux server and want to be able to run as web and mail server with my own domain name.
07-09-2007 3:57 PM
Unless you are moving it to PN to use their email servers. In which case things have not been very rosy on that front lately.
07-09-2007 4:03 PM
I had set up A records for my IP address but using 123-reg mx records for e-mail.
My problem started with not being able to receive e-mail on my domain name. Sending was not a problem. I was getting errors about too many smtp connections and timeouts. So decided to move all to somewhere else and try that. Timing is not too crucial with this at the moment.
07-09-2007 4:42 PM
07-09-2007 5:45 PM
This is the error I'm receiving:
host mx0.123-reg.co.uk [195.224.48.119]: 550 relay not permitted
Do you have any ideas?
07-09-2007 7:45 PM
Problem of receiving e-mail continues
I've ran an open relay test and get:
"All of your mailservers appear to be closed to relaying. mx.last.plus.net OK: 550 REJECTED: Relay not permitted"
I can send e-mails via smtp but when I try and receive via pop nothing happens.
I've tried sending from my plus.com address and receive an undelivered error from Mailer-Deamon:
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
retry time not reached for any host after a long failure period
What do I do now?
08-09-2007 10:04 AM
Second, have you read the help & support pages relating to POP3 and SMTP mail as they do explain how to set things up. You also need to look at the manage my mail section on the portal (under email settings).
Without knowing the email addresses you are using (both from and to) its is difficult to offer any help. Perhaps you can give some examples but using domain instead of your actual domain and username instead of your plusnet name so we have an idea what you are trying to do.
Finally it can take up to 48 hours for things to properly propagate so you may need to wait a while longer before your domain works.
08-09-2007 12:11 PM
08-09-2007 3:54 PM
You need to raise a ticket and get PN to fix the mail setup for your domain. This may fix your mail problems.
Second ,you are using yourname@domain.co.uk (which is the same mailbox as yourname@username.plus.com), is this a named mailbox on your account or does it go to your default mailbox? If a named mailbox, you have to use username+yourname as the POP3 login with its corresponding password. To check this use the webmail link on the member centre page.
08-09-2007 6:21 PM
I've added to mx record at my PN member page.
I've PMd you with some other info.
Thanks again.
09-09-2007 10:05 AM
What is currently happening is mail is being delivered to your mailbox on your plusnet account and not to your mail server where your pop3 mailbox is.
