Mouse
Fixes: 9
Mouse
Have had the same mouse since getting my first computer so think it's time to change from my wired mouse to a more modern one.
Have been looking at these tracker ball mice, anyone use one ? or have any other comments on a  new mouse.
Fixes: 19
Re: Mouse
I used to have a "large" mouse , as standard issue with desktop computers... but since using a laptop, have opted for a "mini mouse".... some are very small, and can cause pain trying to use them for a long while..... so I bought myself "the next size up" , which was still half the size of the "normal" mouse.... then I got the next size up which is similar to this one...
http://www.ebay.co.uk/itm/USB-LED-Optical-Wired-Scroll-Wheel-Mini-Mouse-Mice-For-PC-Laptop-Black-/18...
Which I find very comfortable to use... very accurate, light, and a joy to use....
would never go back to using  half a house brick for a mouse.... can`t understand why they still make them... so heavy, and bulky....
Fixes: 226
Re: Mouse
Coincidently, I have just bought my third Logitech M215. I have one each for our laptops and today's purchase is to replace the one for SWMBO's PC which died this morning.
We both find them very comfortable even though I have quite big hands with long fingers.
Forum Moderator and Customer
Fixes: 20
Re: Mouse
Of course the advantage of a wired mouse is that it doesn't need batteries or recharging.
Fixes: 19
Re: Mouse
And another disadvantage of the wireless mouse..... Price !...
Mine cost just over £3. in Asda...!
VileReynard
Seasoned Pro
Fixes: 11
Re: Mouse
I can recommend the Microsoft mouse.
It's the only decent product they make.  Grin
Re: Mouse
Their keyboards and webcams aren't too bad, just avoid their software  Tongue
MS mice can be pretty good but I find them a bit pricey compared to Logitech
Call me 'w23'
Re: Mouse
I have a Genius and a Microsoft Basic Optical, both have worked for years without hitch. The optical (ball-less) principle does away with mats and cannot fur-up. Both were quite cheap I seem to remember.
Re: Mouse
Quote from: Un
+1 for that.  Cool
Having used lots of PC's over many many years I always buy Microsoft ones for my own use. IntelliMouse.
RPMozley
Fixes: 5
Re: Mouse
Aaaah, de-furring mice. Those were the days.  Crazy
That's RPM to you!!
rongtw
Fixes: 12
Re: Mouse
Mouse Balls are now available as Field Replacement Unit . Therefore, if a mouse fails to operate or should it perform erratically, it may need a ball replacement. Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel.
Before proceeding, determine the type of mouse balls by examining the underside of the mouse.
Domestic balls will be harder and larger than foreign balls.
Ball removal procedures differ depending on the manufacturer of the mouse. Foreign balls can be replaced using the pop-off method. Domestic balls are replaced using the twist off method.
Mouse Balls are usually not static sensitive. However, excessive handling can result in sudden discharge.
Upon completion of ball replacement, the mouse may be used immediately.
It is recommended that each replacer have a pair of spare balls for maintaining optimum customer satisfaction, and that any customer missing his balls should suspect local personnel of removing these necessary items.
VileReynard
Seasoned Pro
Fixes: 11
Re: Mouse
Have you ever taken a mouse apart?
It's astonishing how flimsy they are inside.
I don't know how the ball can manage to operate to the customers satisfaction.
