Mouse scroll wheel running backwards????
Fixes: 15
IN my new M13 install my mouse wheel is scrolling backwards - ie I scroll up the screen scrolls down.
Anybody know how to fix it?
Fixes: 15
Re: Mouse scroll wheel running backwards????
Also a keyboard issue:-
I can't get Meta+E to launch Nautilus though any ideas on that.
(Meta+T works for terminal so not a keyboard issue)
Fixes: 15
Ok found the answer myself
open .Xmodmap and change the "3 5 4" to "3 4 5"
so it looks like this now.
pointer = 1 2 3 4 5 6 7 8 9 10 11 12
VileReynard
Seasoned Pro
Fixes: 9
Quote from: Hairy
Turn your screen or mouse (but not both) upside down.
Fixes: 15
Ha Ha. But it was ONLY the mouse wheel that was backwards. (So called apple Human mode  Crazy) And I fixed it see above.
