More free space on C drive after installing Vista SP2?
randpwar
Installed Vista SP2 Saturday and have noticed that the free space on the C drive has increased by about 70 odd gig  Cheesy from the 356 ish gig available after picking the new pc up from the shop following the initial load, to 430? As far as I can tell everything works as before and no documents, music or photo’s etc are missing; so is this a deliberate part of the SP to in some way compress the volume?
As I say, all is working well and while the extra free space is welcome I hardly need it yet. But how does this come about?  Huh
Fixes: 189
Re: More free space on C drive after installing Vista SP2?
some info here http://lifehacker.com/5273780/installing-vista-sp2-might-free-up-hard-drive-space
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
scootie
didnt in my case but i use perfect disk to aggeasively consoldate free space anyway
Denzil
My guess would be old restore points being removed. They can occupy a huge amount of space.
