Monitor...Colour Space
- Monitor...Colour Space
18-07-2014 3:51 PM
Recently treated myself to a new colour monitor as I do a fair bit of photography,there are a range of options under the colour space menu,
Adobe RGB
Apple RGB
CIE
Colour match RGB
Dell S2340 Colour profile
Monitor
Pal/SECAM
ProphotoRGB
SMPTE - C
Does it make much difference to which one I use ? Will it make much difference if any to printed photography & if not what's the point in having this range of options ?
Adobe RGB
Apple RGB
CIE
Colour match RGB
Monitor
Pal/SECAM
ProphotoRGB
SMPTE - C
We are born into history and history is born into us.
2 REPLIES 2
Re: Monitor...Colour Space
18-07-2014 5:37 PM
Read this >
http://www.pcworld.com/article/241957/how_to_calibrate_your_monitor.html
I'd guess, if you're using Photoshop Adobe RGB and set PS to use that too?
18-07-2014 6:47 PM
Thanks for the response, I do have a fairly old calibrator, so old that I had to download the software to use it with windows 7, like you I could hardly see any difference.
Although the monitor is upgraded and photos look great, it could get quite expensive to upgrade to a top class printer along with all the other accessories such as printer calibration, professional photography paper & the rest.
