Monitor Advice
- Re: Monitor Advice
Monitor Advice
23-11-2015 8:23 PM
Re: Monitor Advice
23-11-2015 8:54 PM
All depends what you want it for, of course...
Re: Monitor Advice
23-11-2015 9:43 PM
My last one was an IIyama ProLite XUB2790HS and I am delighted with it
Re: Monitor Advice
23-11-2015 9:53 PM
Re: Monitor Advice
23-11-2015 10:10 PM
This would be a good choice http://www.amazon.co.uk/IIYAMA-ProLite-XU2290HS-B1-Widescreen-Monitor/dp/B00HY77URI/ref=sr_1_2?s=com... and I recommend buying from Amazon as, if there are any dead pixels their no quibble return system is magnificent
http://www.iiyama.com/gb_en/products/pprolite-xu2290hs-1/
Re: Monitor Advice
23-11-2015 10:28 PM
I might buy it when my winter fuerl allowance lands in my bank account
Re: Monitor Advice
23-11-2015 10:36 PM
Re: Monitor Advice
23-11-2015 10:44 PM
Re: Monitor Advice
24-11-2015 12:07 AM
LCD is the physical technology f the panel. LED is the way it is illuminated. And IPS is the way the screen is addressed to show the picture.
Re: Monitor Advice
24-11-2015 5:50 AM
Re: Monitor Advice
25-11-2015 7:14 PM
LED. HDMI, DVI, the refresh rate is good, runs from HDMI card, had them for about two years, they are wall mounted in my workshop.
Am considering converting my desktop (currently Samsung SyncMasters) to BenQ as was impressed them.
Re: Monitor Advice
27-11-2015 2:07 PM
Some monitors switch off automatically when the PC is turned off and some have to be turned off manually. Is this a function of the PC or the monitor?
I will be moving from a 4:3 to a 16:9 format. Things like a word document or a website will be adjusted to the new format. What happens to pictures I have stored on the PC? As I type this I think I know the answer but will ask it any way.
Re: Monitor Advice
27-11-2015 2:42 PM
However a word of warning
Check the screen height as a 22" 16:9 is much shallower than a normal 4:3
https://en.wikipedia.org/wiki/Display_size
a 16:9 22" is about the same height as a 17" 4:3
This why when I changed my 22" 16:10 to a 16:9 I went to 27" although a 24" would have given the same height as I had previously
Re: Monitor Advice
27-11-2015 2:46 PM
Re: Monitor Advice
27-11-2015 5:50 PM
some that are powered via the pc operate differently again by having the psu disable the output when the pc shuts down /
