Modem/router upgrade
- Re: Modem/router upgrade
30-12-2018 3:38 PM
Hi All. Right before fibre I always had my router upstairs which was plugged into the BT master socket via a 3m cat5 cable But then when I had fibre I had the modem that was supplied by Bt/Plusnet and plugged into the original cat5 that went to the bedroom and the new twin channel router. Because all my original network items where terminated in the bedroom. However Iv been given a very good quality gigabit switch so now is the time Iv thought about having a combined modem and router downstairs by the Bt masterplug. So I am looking for suggestions please. I’m mainly doing this as I’m needing 3 cat5/6 cables downstairs and rather than running them back down I can get the new unit and run them from this while the original modem to router cable can go to the gigabitswitch and all upstairs cables can plug into that?
Does this sound like a plan or can anyone suggest a better way or any other suggestions oh the 3 cat5/6 cables I need downstairs are for PC streaming media hub and TV Upstairs where was where I wired the house and radio shack in cat/5 sockets in every room and terminated them to a patch panel in my bedroom by my original modem
Like I say if no other ways can be thought of then suggestions are needed for the modem/router please and it needs to be at least twin channel 2.4 and 5Ghz
thank you in advance.
Regards OS
30-12-2018 3:50 PM
I'm a bit confused to what you're asking but if I've got it right then if you put a combined modem router downstairs then this will give you 4 LAN sockets. 3 can be used for your downstairs devices and the 4th used for the cable going upstairs. Upstairs you put your new switch on the other end of this cable and you have the upstairs ports from this for your other devices,
31-12-2018 3:39 AM
Hello Baldrick 1. You have it spot on. And I just wondered if that was the best way of doing what I wanted. Because there is nothing wrong with either the modem or the router the main thing is needing the extra 3 cat5/6 cables.
So I think the whole point of the post is asking for modem/router suggestions please?
Thanks OS
31-12-2018 7:52 AM
Just bought a BT business hub 6 off ebay for £40 brand new which is a combined modem/router with the 4 gigabit cat6 sockets you require. Only had it a week but so far it does just what I want including Plusnet TV and has been rock solid.
I have a similar system to yours except my patch panel and gigabit switch is in the garage out of sight and all that.
Gerry.
31-12-2018 9:55 AM
Yes this is the best way
I also use a busness Smarthub 6, see here for setting it up. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85... I paid less than £20 including postage for the last one I bought from EBay so it's worth keeping an eye out for the bargains.
31-12-2018 9:59 AM
Moderators Note
This topic has been moved from Fibre to Tech Help
