Modem advice please
- Re: Modem advice please
Modem advice please
07-09-2015 5:43 PM
All the green lights are on, no amber or red lights.
It's a plusnet modem for fibre and is connected to a BT router.
When it drops the signal I get the standard message, cannot connect to server, checked with a wired desktop & 2 tablets so certain the problem is with the modem.
Two questions, first is this a sign of the modem packing up and the second question can you recommend a reasonable priced reliable modem I could replace it with ?
Signal strength is showing as very good so that is not the issue.
07-09-2015 5:49 PM
Quote from: gleneagles is this a sign of the modem packing up
It's often a sign that the wireless functionality is packing up.
07-09-2015 6:41 PM
07-09-2015 8:14 PM
Login details are usually on the back of the router itself and you will need to know the IP address of the router too.
07-09-2015 8:57 PM
HowTo for the TG582n router:
http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
08-09-2015 2:01 PM
Some useful information in your posts.
Will try those suggestion out.
11-09-2015 12:38 PM
The advice offered here may help you out too:
http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
11-09-2015 7:26 PM
Quote from: ReedRichards It's often a sign that the wireless functionality is packing up.
Yeah they have a habit of becoming flaky.. yet for some reason ethernet switches live forever. How that works is beyond me.
Personally I'd build a mini itx machine and put a PCI wifi card in and set it to AP. I have a ralink 2500 based PCI card and despite years of use it's never once let me down. For some reason the PCI cards seem to be more reliable than the wifi devices built into routers and printers.
11-09-2015 9:46 PM
but like everything it seems its a lottery, I had had a naff old BT voyager last nearly 5 years and yet went through 4 hubs in a year (all wifi problems) before I switched to wired only and that router lasted almost 6 years and 2 house moves (billion 7800 not the wifi version) and got replaced as the main router only because I needed wifi........
11-09-2015 11:40 PM
One day i had the switch panel down from the ceiling where the sunroof switch is (along with 3 other switches). While up there i noticed lots of condensation droplets up there and the wires in the connectors that were plugged into the switches were wet. Bingo! Wrapped them all up in leccy insulating tape so that the water would run down the outside of the connector and not had the problem since!
Funny old world..
