Mobile phone connection using Windows 7 on Nokia Lumia 710
henrym
How can I get my mobile phone to sync with my plusnet e-mail account. I have used the settings issued by Plusnet but to no avail
1 REPLY
Fixes: 62
Re: Mobile phone connection using Windows 7 on Nokia Lumia 710
Can you be a bit clearer as to what you are trying to do.
The reference to Windows 7 in the title is a bit confusing. If that is relevant which email client are you using on Windows
