Mobile broadband dongles
SteveA
I'm getting tired of having to use a LG mobile phone as mobile modem when I'm on the boat so I'm looking round at Mobile broadband dongles.
Now I know that some don't play well with Linux so I was hoping people might be able to tell me which dongles (and from which Mobile phone company) work with Ubuntu.
2 REPLIES 2
Fixes: 395
Re: Mobile broadband dongles
That depends on which version of Ubuntu, up to 9.04 most of the Huawei dongles seemed to work ok, 9.10 broke quite a few of them but I think the latest kernel updates have them working again. I've got a ZTE MF627 from '3' and that works pretty well with 9.04 and actually comes with some Linux UI software which allows for SMS sending/receiving, although in order to use it you need to stop Network Manager claiming the modem. A colleague has a Vodafone PAYG K3520 and that works ok with 9.04 also and again you can download Vodafone Mobile Connect if you don't wish to use Network Manager.
If you've googled a little ( which judging by your post I guess you have ) you will know that these dongles initially appear as a CD and have to be 'switched' out of this mode under Linux, by ejecting the CD drive or 'modeswitch'. With my MF627 I discovered that you can disable the CD semi permanently by sending it an AT command, of course you need to do this initially on a Windows box where it is seen as a modem. Once this is done then its a doddle in Linux because its seen immediately as a modem and therefore needs no 'ejecting'.
Hope that helps for a start. Post back with any more questions and I'll try to help.
SteveA
Well I did more reading and the Huawei modems seemed to be the ones to go for, and I found this article : http://www.watkissonline.co.uk/wordpress/?p=1853
So I decided to try O2 who seem to have a signal in most of the places I'd want to go.
My local Sainsbury's sells the O2 PAYG dongle for £19 so I picked one up with the shopping. As my laptop dual boots into Vista I set it up in Vista first and made sure it all worked. Then I booted into Ubuntu (Karmic) and plugged the dongle in. It appeared on the desktop but didn't auto detect. So I went to the network options and chose to add a new mobile network. It detected the modem and I used the settings in that post and it worked perfectly.
It also works on the eepc too (which is on 9.04).
You don't get the Wfii Hotspot support - thats only available under Windows but apart from that it seems to be good.
