Mobile Phone app
shutter
Fixes: 67
Mobile Phone app
Is there a mobile phone app that I can use, to give the message " Please text me" rather than the phone going to VoiceMail? when I cannot answer the phone.
3 REPLIES 3
Fixes: 1,495
Re: Mobile Phone app
Assuming you have android a quick google (who knew?) gives this as a possibility
https://www.techbout.com/answer-calls-with-text-messages-android-phone-47/
RobPN
Fixes: 15
It's not clear from your question whether you cannot answer the phone because you hear the phone ring but you're doing something else and it's not convenient to answer, or whether you're perhaps asleep or not near the phone when it rings so unable to take the call.
I guess a start might be to switch voicemail off, but Android has a feature with a series of quick response messages you can use when you hear the phone ring and don't wish to answer a call.
A quick Google found the following;
shutter
Fixes: 67
@dvorak  Thanks for the linky...Wink I have modified one of the text messages which may do the job. Smiley I did google, but probably asked the wrong question !  Huh
