Mobile Email Settings
Is it possible for me to access my plusnet business emails by mobile phone? I spend a lot of my time out on site and could do with accessing them through the phone without having to spark up the laptop. My phone is a samsung soul & I think it has pop3 not sure though.
Any help or links to the PN mobile settings appreciated.
James
Re: Mobile Email Settings
Hiya,
Do you know if your mobile supports authenticated smtp?  If so, you should be able to check your email using mail.plus.net as the incoming mail server and relay.plus.net as the outgoing, but making sure you set smtp to authenticated.
Thank you James my phone did and it works a treat  Cool
