Mobile Email Settings
- Mobile Email Settings
01-06-2009 1:08 PM
Is it possible for me to access my plusnet business emails by mobile phone? I spend a lot of my time out on site and could do with accessing them through the phone without having to spark up the laptop. My phone is a samsung soul & I think it has pop3 not sure though.
Any help or links to the PN mobile settings appreciated.
2 REPLIES 2
Re: Mobile Email Settings
01-06-2009 1:33 PM
Hiya,
Do you know if your mobile supports authenticated smtp? If so, you should be able to check your email using mail.plus.net as the incoming mail server and relay.plus.net as the outgoing, but making sure you set smtp to authenticated.
02-06-2009 10:02 AM
Thank you James my phone did and it works a treat
