Mixing Powerline Adapters
- Re: Mixing Powerline Adapters
14-02-2014 4:55 PM
Wondered if I can add one of these http://uk.tp-link.com/products/details/?categoryid=1658&model=TL-PA451 as the place I want to use it has no spare sockets?
14-02-2014 5:00 PM
Standards and Protocols HomePlug AV, IEEE802.3, IEEE802.3u
So yes, 100% compatible.
14-02-2014 5:19 PM
14-02-2014 5:32 PM
16-02-2014 2:16 PM
They work in pairs and can talk to each other via a common switch.
17-02-2014 9:41 AM
However: What I noticed with powerline adapters, are sudden spikes in latency, sometimes quite big spikes, and sometimes quite regular. I've went back to cable and abusing a wireless router to turn it into an extender.
Which reminds me, I still have a bunch of powerline adapters plugged in, although only 2 of em are currently in use.
If you not bothered about occasional latency, you can't hide wires, or you live in a castle with thick walls - Powerline adapters work. For time critical applications however...
17-02-2014 10:13 AM
19-02-2014 11:53 AM
19-02-2014 3:11 PM
I can run big downloads and backups simultaneously - the router will max out at a bit less than 100Mbps.
(Or possibly more if you have a Gigabit router).
