Mixing Powerline Adapters
sully666
Have been using these for a few weeks http://uk.tp-link.com/products/details/?categoryid=1658&model=TL-PA4010KIT.
Wondered if I can add one of these http://uk.tp-link.com/products/details/?categoryid=1658&model=TL-PA451 as the place I want to use it has no spare sockets?
Fixes: 10
Re: Mixing Powerline Adapters
If you look at the specification both say
Standards and Protocols HomePlug AV, IEEE802.3, IEEE802.3u
So yes, 100% compatible.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
sully666
Excellent  Grin
Fixes: 103
I think I'm using an older iteration of those plugs. I have 2 x 500Mbps plugs and one 200Mbps plug on the same network and they're all able to talk to each other without any issues.
VileReynard
All Star
Fixes: 11
I have two 85Mbs plugs and two 1000Mbs (claimed) plugs on the same network.
They work in pairs and can talk to each other via a common switch.
TimeRider
Great things if you need em, we use a lot of these on site, and sell quite a few from the store.
However: What I noticed with powerline adapters, are sudden spikes in latency, sometimes quite big spikes, and sometimes quite regular. I've went back to cable and abusing a wireless router to turn it into an extender.
Which reminds me, I still have a bunch of powerline adapters plugged in, although only 2 of em are currently in use.
If you not bothered about occasional latency, you can't hide wires, or you live in a castle with thick walls - Powerline adapters work. For time critical applications however...
Fixes: 103
I've never noticed latency spikes with my setup. Regularly use it to stream HD media/music across the local network.
sully666
Been thinking about this, and wonder if the adapter plugged into the router will cope with bandwidth coming from the adapter my son's XBox AND a new adapter for his PC? Or would I be better just leaving his PC on the wifi?
VileReynard
All Star
Fixes: 11
Yes it will cope.
I can run big downloads and backups simultaneously - the router will max out at a bit less than 100Mbps.
(Or possibly more if you have a Gigabit router).  Grin
