Missing portal webstats for Wednesday 14 April
- Missing portal webstats for Wednesday 14 April
15-04-2010 9:50 AM
No Service Status. No nothing. And probably too late in the day to raise a ticket.
Dont know if this is the correct forum with the reorganisation.
Ticket 32964848 raised but 22 hours is hopeless.
3 REPLIES 3
Re: Missing portal webstats for Wednesday 14 April
15-04-2010 10:05 AM
I'm checking on the webstats now, it's likely they are delayed due to the product updates last night.
15-04-2010 12:18 PM
Thanks for checking this out Chris. I got your email from Support. And they are on the way. This new delivery time around 8 o'clock makes it difficult to spot when they have failed to run. Cheers.
15-04-2010 5:01 PM
These should now be generated and available via the portal. I've checked a couple of accounts and they are there so will close the service status shortly.
