Missing or corrupt Windows\Ststem32\config\System
juliasdream
When I try to boot Win XP I get the error message "Missing or corrupt Windows\Ststem32\config\System
I tried using the Setup disc typing R for Recovery
In the so-called Recovery console I get the option to select 1: C:\WINDOWS or abort
When I select 1: I just get C:\Windows>
Its not clear where I go from there
I dont want to re-install just yetr because I lost the win key and need to get the system running in order to run Jellybean Keyfinder to retrieve it
Can anyone help?
Fixes: 24
Re: Missing or corrupt Windows\Ststem32\config\System
You need to follow the instructions here:
http://support.microsoft.com/kb/307545
This takes a little time but it really does work!
If there is no obvious cause for the corrupt registry, like a power failure or a computer crash, then it may be a sign that your hard disk is reaching the end of its life.
I've used that process several times (professionally), indeed I've even done variations on it (taken some shortcuts) but that's definitely not for the uninitiated.
It's a bit scary for most people so get a knowledgeable PC person to help if appropriate. It's also good to have a second system up and running in case you need to check anything online.
Fixes: 24
From the blurb at http://www.magicaljellybean.com/keyfinder/
"Another feature is the ability to retrieve product keys from unbootable Windows installations."
So maybe you don't need to get your system running again?  Better read the instructions!
