Missing dll file
Missing dll file
When I clicked a link in an email to open a WMV file I got a message:
This application has failed to start because MSVCC71.dll was not found. Re-installing the application may fix the problem.
Is there an Idiot's Guide to solving this problem?
I looked on google and that led me to a site that was trying to sell me a prog to do it.
Fixes: 20
Re: Missing dll file
try here http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
Just click on the free link. and unzip it when you get it, put it in the c:\win\system32 folder.
Thanks Biker.  I will give it a go later.
Fixes: 17
The linky that Biker is on about, is at the bottom of the screen !.... Cool
Click here to go to the download of msvcr71.dll
the others at the top are "adverts" ! !  Undecided
Fixes: 194
That linky is also to a different DLL - MSVCR71 no MSVCC71
@Artmo double check your error before downloading it.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 20
OOPS! sorry about that.
As to it being at the bottom I use FF and adblock plus, it was at the top on the right  Grin
And that site isn't bad for getting the odd dll from. You could always search the M$ site for it
Fixes: 86
MSVCC71 not found. Search suggested MSVCR71 Wink
Customer and Forum Moderator.
Fixes: 17
I use FF as well !.... strange !  Undecided ..... I hate those pages where you have to "search high and low" to find the correct linky to what you want, instead of the so called "helpful" links to sort out your computer problems........ at a cost !.... which are usually more prominently displayed ...... Shocked
Fixes: 62
but have you installed Adblock Plus
Fixes: 17
Moi?    probably not..... I assume they are "part of the page"!    not seperate "google ads" or pop-up ads.....
Fixes: 62
This is what it looks like with Adblock Plus
Fixes: 20
not on my Linux system!
Strange!
Or was that step One?
Fixes: 62
That was from the link in your first post
Fixes: 20
Thats the screen I get when I click on the link on my post. Strange as I said.
Thanks guys for the additional info.
Strat, yes I made a typo error  Embarrassed.  I meant MSVCR71.
