Missing dll file
- Re: Missing dll file
Missing dll file
01-02-2010 10:12 AM
This application has failed to start because MSVCC71.dll was not found. Re-installing the application may fix the problem.
Is there an Idiot's Guide to solving this problem?
I looked on google and that led me to a site that was trying to sell me a prog to do it.
01-02-2010 10:15 AM
Just click on the free link. and unzip it when you get it, put it in the c:\win\system32 folder.
01-02-2010 10:49 AM
01-02-2010 11:07 AM
Click here to go to the download of msvcr71.dll
the others at the top are "adverts" ! !
01-02-2010 11:12 AM
@Artmo double check your error before downloading it.
01-02-2010 11:22 AM
As to it being at the bottom I use FF and adblock plus, it was at the top on the right
And that site isn't bad for getting the odd dll from. You could always search the M$ site for it
01-02-2010 11:31 AM
01-02-2010 11:52 AM
01-02-2010 2:05 PM
01-02-2010 2:16 PM
01-02-2010 2:23 PM
01-02-2010 2:59 PM
Strange!
Or was that step One?
01-02-2010 3:23 PM
01-02-2010 4:39 PM
01-02-2010 6:56 PM
Strat, yes I made a typo error :-[. I meant MSVCR71.
