Missing MRUs
- Re: Missing MRUs
Missing MRUs
09-06-2009 12:06 PM
When I use advanced system care to clean out missing files and other rubbish on my computer I get a long list of ' Missing MRU files' What are these and is there any way to avoid these ?
We are born into history and history is born into us.
1 REPLY 1
Re: Missing MRUs
09-06-2009 12:41 PM
answer from another forum (Lavasoft)
Quote Hi, Gloria. MRU (Most Recently Used) items are nothing more than lists of the most recent files accessed by various processes/programs on your system. For example, if you open any of the MS Office products they display a list of the last several files that were created/edited. These are normal system features and not the result of any malware.
Some people consider these a privacy concern and clear them out. Others, like myself, appreciate the convenience that they offer and keep them.
You can prevent Ad-Aware from reporting these by deselecting the "Search for negligible risk entries" switch in the Preparing System Scan pane which appears after you click the Scan now button.
