Missing Channel on Freeview
FIXED- Subscribe to RSS Feed
- Missing Channel on Freeview
24-03-2018 7:21 PM
Checking out the progs listed on
http://www.tvguide.co.uk/?systemid=3&cTime=2/12/2014%207:00:00%20PM&thisTime=&thisDay=&catColor=
I thought I would like to watch VIVA on Freeview Channel 57 ...
However, despite a re-tune on 21st ( as notified with a popup message on screen on the telly ).. I can`t get Ch57
Anyone know why ?
Are some Freeview channels only available on-line ? if so, they should not be listed as on Free View progam channel lists.
Fixed! Go to the fix.
Re: Missing Channel on Freeview
24-03-2018 7:26 PM
Looks like it has closed...
https://www.a516digital.com/2018/01/viva-drops-off-freesat.html
24-03-2018 7:32 PM
@Anonymous
Thanks for the research, and linky...
24-03-2018 7:51 PM
Poxy freeview retune popups.. they annoy the hell out of me - we see it every day on the panasonic vierra we have. Arguably not the greatest quality TV ever made..
We have a few channels listed that we can't watch or only intermittently able to - 5Spike being one of them.
25-03-2018 7:07 AM
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
25-03-2018 3:13 PM
VIVA has been coming and going for a few years now; at one point they broadcast for about four hours in the middle of the day I think.
I discovered my Channel 4+1 HD said "not broadcasting or encrypted" when I tried it on 21st before I remembered the retune reminders that had been popping up. However, after the retune the signal strength on that channel and a few other HD ones was so poor that it was unwatchable. By Friday night it seemed to be adequate again (30% - the minimum required for HD I understand) but not as good as previously (75% or thereabouts).
I find https://ukfree.tv/section/News_headlines useful for any TV reception related matters (although it isn't always easy to navigate).
30-03-2018 8:02 PM
I notice that Freeview Channel 10 (ITV3) has disappeared. I can now get the programme on Channel 788 !!
30-03-2018 11:27 PM
It's still on Channel 10 at Crystal Palace...
31-03-2018 10:44 AM
If you are having issues with a particular channel that persist after a retune the first thing to check is if you can still get other channels on the same Mux - see http://www.digitaluk.co.uk/channels/channel_listings. If you can it's not the signal or the TV, it's the broadcaster.
If it is all the channels on the Mux check you are using the correct Mux channel. Use the Coverage checker on http://www.digitaluk.co.uk/home - tick the detailed view box. That will tell you the channel numbers and likely reception. You can use the channel numbers to manually refresh that single channel on most TVs etc.
