Mint 17.1 upgrade problem (Solved)
gleneagles
Aspiring Legend
Fixes: 17
Have 2 computers running linux Mint 17, the upgrade installed fine on the first one but the second one I am having problems with,
Followed all the instructions and everything appeared to be downloading ok but then the message .........Failed to fetch http://packages. Could not connect to packages linuxmint com:80 (204.45.82.194) connection timed out.
Upgrade not successful.
Anyone any ideas ?
NB: Managed to upgrade successfully at the third attempt !
We are born into history and history is born into us.
1 REPLY 1
HairyMcbiker
All Star
Fixes: 21
Re: Mint 17.1 upgrade problem (Solved)
Strange maybe heavy usage with upgraders? You could have tried an alternative source (software-sources app)
