Mint 16RC "released"
- Re: Mint 16RC "released"
14-11-2013 2:12 PM
http://www.mirrorservice.org/sites/www.linuxmint.com/pub/linuxmint.com/testing/
14-11-2013 11:13 PM
15-11-2013 10:07 AM
It has the latest versions of everything included. Mate 1.6, Cinnamon 2.0 etc.
It also breaks severely awn Even with the new patched version I can't get 2 docks on screen.
15-11-2013 12:46 PM
I don't use awn.
15-11-2013 2:34 PM
22-11-2013 4:38 PM
wine will not install on 64bit systems.
Crossover 12 works but had to install some additional libs, luckily they tell you what is needed
27-11-2013 6:10 PM
Running happily on my system at the moment. (Mate edition still don't like Cinnamon)
27-11-2013 8:40 PM
It was a gigantic kludge when Ubuntu added 64 bit libs AND 32 bit libs.
28-11-2013 9:37 AM
01-12-2013 2:20 PM
01-12-2013 3:49 PM
01-12-2013 4:11 PM
Quote from: 30FTTC06 Kernel: 3.11.0
01-12-2013 5:02 PM
01-12-2013 5:33 PM
what do you guys' use ?
01-12-2013 5:44 PM
Otherwise same as you Mate 64bit Mint 16.
