Mint 16 KDE xfce
30FTTC06
Fixes: 4
Mint 16 KDE xfce
10 REPLIES 10
HairyMcbiker
All Star
Fixes: 21
Re: Mint 16 KDE xfce
Prefer the Mate edition.
VileReynard
Fixes: 20
When is the next major update for LMDE Mint expected?
(Yes, I made the conversion)!  Cheesy
HairyMcbiker
All Star
Fixes: 21
Jan, SP8 will be released then.
VileReynard
Fixes: 20
Thanks - it's a bit weird, not getting frequent updates.
HairyMcbiker
All Star
Fixes: 21
You still get the essential ones, but not all the others.
The SP is a bit like a dist upgrade, takes a while to install  Shocked
shutter
Fixes: 64
Same as WIndows, then  Cheesy Roll_eyes
HairyMcbiker
All Star
Fixes: 21
Naw I ain't talking all day to install then install updates. Something along the lines of 20-30min,
shutter
Fixes: 64
Like I said....... A bit like Windows.....
Did an update this morning on my FREE wifi SAMBA dongle.... took 10 minutes to download, install and re-boot... so faster than Mint on this occasion !
HairyMcbiker
All Star
Fixes: 21
Not at all like M$. unless you can update your XP to W7/8 for FREE and then to the next version again for FREE?  Grin
With LMDE it is a ROLLING update. You NEVER have to re-install it or install a new version it is kept up to date with new releases as required.
And usually NO REBOOT is required unless a new kernel is installed.  Wink
VileReynard
Fixes: 20
When I did the initial install, the download was about 5 months out of date.
It only took about 15 minutes to load the missing software instalment (I've got a good fibre connection).
It's not like one of those awful Windows service packs and you can generally still continue
to safely run various other tasks, although I tend to follow the install log, to see what new
stuff is being added/updated.
