Mint 14
gleneagles
Aspiring Legend
Fixes: 17
Mint 14
This links in a bit with strats earlier post regarding wi-fi and Linux.
I Had one computer linked via ethernet cable and it worked fine but I have now shifted it to an alternative site and need to use Wi-Fi but it's now behaving erratically works for a short period then a pop up box appears asking me for my router password and also tells me a wired cable is unplugged.
Is there any command to delete this cable connection message ?
We are born into history and history is born into us.
2 REPLIES 2
HairyMcbiker
All Star
Fixes: 21
Re: Mint 14
You could disable the nic. Left click on the Network icon and choose disable networking.
This will stop the no cable errors.
gleneagles
Aspiring Legend
Fixes: 17
Re: Mint 14
Thank you.
