Millheat app
Pityme
Millheat app
Have installed Wi-fi radiators and can use all ok on local network. The rads show offline so Millheat checked visible on their server but offline through the app. Firewall is off but guess some other port forwarding might be needed....novice so advice welcomed please.
peter
3 REPLIES 3
Mav
Fixes: 512
Re: Millheat app
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
Mav
Fixes: 512
Re: Millheat app
Moderator's note:
@Pityme
I have removed the fix as all I did was move your thread to the correct board. Your question remains unaswered.
Pityme
Re: Millheat app
It was an internal Wi-fi issue and millheat advised so help is not required thanks. Happy to close thread.
