Microsoft word - auto inset
- Microsoft word - auto inset
07-06-2010 9:11 PM
Can anyone tell me how to stop my word program from insetting (or is it tabbing?) every line.
I'm using Word 2003. I write a letter, say, and allow the program to wrap text as normal (in other words I don't press ENTER) but instead of going to the start of a line the program starts the next line with an inset. I've looked all over the tools 'options' but can't find anything relating to stopping this automatic inset.
No doubt one of you geeks can tell me some easy process I am missing but nevermind I don't mind appearing stupid - I just want to stop it !
2 REPLIES 2
Re: Microsoft word - auto inset
07-06-2010 9:24 PM
Click on View then tick ruler and it will look something like this picture
Note the position of the circled tabs and the style
I assume that your normal template has got messed up
This is one way to change it in Word 2003 choose Format Styles and Formatting, right-click the Normal item in the Styles and Formatting pane, click the Modify button, and work in the Modify Style dialog box as per the second picture - don't forget to tick - add to template and don't tick automatically update
08-06-2010 7:50 PM
Thanks very much Oldjim. I had a bit of a struggle understanding but that was mainly because I didn't
properly read your two 'cropimages'. Alls well however and back to normal (I think!)
The problem was entirely that - somehow - I had managed to put in a normal+ 2 cm hanging tab.
