Microsoft Outlook Question
julesandsand
I use Outlook 2007 in W7 Pro. The Business contact toolbar is shown, when I right click on the toolbar >customize, I can't uncheck Business toolbar. I can, however select 'Delete', which I do and the toolbar disappears. However as soon as I quit, the blasted thing reappears!
It's bugging me!
Steve
Seasoned Pro
Re: Microsoft Outlook Question
Start-Control panel-Programmes and features-remove toolbar. Or this link may be of use to you.http://support.microsoft.com/kb/828245
If life gives you lemons, make lemonade.
julesandsand
Quote from: Steve
In start>control panel>programs and features - there is no 'remove toolbar'.
the official Microsoft workaround doesn't work around it!  Cry
