Microsoft Outlook Question
- Microsoft Outlook Question
06-09-2010 5:41 PM
I use Outlook 2007 in W7 Pro. The Business contact toolbar is shown, when I right click on the toolbar >customize, I can't uncheck Business toolbar. I can, however select 'Delete', which I do and the toolbar disappears. However as soon as I quit, the blasted thing reappears!
It's bugging me!
It's bugging me!
2 REPLIES 2
Re: Microsoft Outlook Question
06-09-2010 6:20 PM
Start-Control panel-Programmes and features-remove toolbar. Or this link may be of use to you.http://support.microsoft.com/kb/828245
If life gives you lemons, make lemonade.
06-09-2010 7:34 PM
Quote from: Steve Start-Control panel-Programmes and features-remove toolbar. Or this link may be of use to you.http://support.microsoft.com/kb/828245
In start>control panel>programs and features - there is no 'remove toolbar'.
the official Microsoft workaround doesn't work around it!
