Microsoft Exchange problem
- Microsoft Exchange problem
15-07-2009 11:18 AM
I use Microsoft Outlook to receive my emails and I am able to do this perfectly ok with my HTC Tytn II mobile but for some strange reason I'm unable to receive them on my PC.
I haven't changed anything (as far as I know) and it was working fine on Friday but not since Sunday.
Unfortunately the Guy who hosts my email server has emigrated and I can't get hold of him. Brilliant
Any ideas?
Re: Microsoft Exchange problem
15-07-2009 11:21 AM
15-07-2009 11:42 AM
15-07-2009 12:53 PM
15-07-2009 12:58 PM
15-07-2009 1:37 PM
! Task 'Microsoft Exchange Server' reported error (0x8004011D) : 'The server is not available. Contact your administrator if this condition persists.'
15-07-2009 1:42 PM
or here http://slashstar.com/blogs/tim/archive/2005/12/02/Outlook-Exchange-0x8004011D.aspx
16-07-2009 12:51 PM
I followed the one which suggested removing the profile and starting again but I am now having problems setting it back up again.
I can't get hold of the guy who runs the email server and wondered if I could find these settings somewhere else.
Any ideas?
16-07-2009 1:24 PM
16-07-2009 6:05 PM
17-07-2009 8:39 AM
18-07-2009 6:36 PM
Quote from: ReedRichards David, it sounds to me as if you are digging yourself deeper and deeper into a hole. You should have made a careful note of your settings before removing the old ones! However if your 'HTC Tytn II mobile' can receive your emails then presumably you can look the settings up on that. Apart from the password; that you just have to know.
I've just been contacted by my elusive IT guy and he has told me that there is a fault with the outlook side of things which he is looking into.
I had set up the profile correctly but the problem was his side.
I'm using the web access so I'm not in too much of a pickle now.
Thanks for all your help
