Microfilter and splitter from main socket
- Re: Microfilter and splitter from main socket
20-10-2019 9:21 PM
20-10-2019 9:34 PM
Micro filter first in the Master Socket, the idea being that anything after that is filtered.
20-10-2019 9:37 PM
20-10-2019 9:51 PM
Yes. Although you also mentioned a splutter - is that for a phone and the Alarm?
If the Alarm has a [hone plug you are lucky, a friend called me to ask for some help, the Alarm fitter had wided the alarm directly into the master socket - once that was sorted their speed doubled.
20-10-2019 10:14 PM
20-10-2019 10:21 PM - edited 20-10-2019 10:22 PM
I agree, you shouldn’t need a splitter as the alarm should be able to plug directly into the microfilter, assuming the cable from the alarm fits.
I think you’d just need the splitter if you have a home phone handset too as you’d then need a splitter to provide an additional phone socket/connection.
Hope this helps.
20-10-2019 11:30 PM
