Micro usb part 2
HairyMcbiker
All Star
Fixes: 21
Micro usb part 2
Just come across this issue:
That is the new plug (90 degree one) is shorter than the normal, the result is it will not fit in my phone. Cry
I am thinking about getting creative with a scalpel (done it before on a round plug that was too short to fit in the socket).
Anybody else come across this issue ?
12 REPLIES 12
Re: Micro usb part 2
I have but never given it much thought TBH, could this change in size be related to the USB type i.e. A, B, C?
w23
Fixes: 4
At the risk of using very technical terminology (apologies if it's too technical Grin), it looks to me like the 'sticky-out bit' on the blue one is sticking out more than a standard normal one does (looking at any I have lying around, they all stick out a bit less than that one (but maybe a bit more than your black 90° one).
No, I don't have a vernier handy to measure one. Wink
http://hwbb.googlecode.com/svn/trunk/Interface/USB/DATASHEET/USB%20cable/uUSB_1%200%20(publication)_...
Apparently it should be 5.4mm
Call me 'w23'
shutter
Fixes: 65
Interesting.... I just looked at a couple of my connectors.... and yes... there is a difference in the length... however.. there is also a difference in the "cross section" size...   the one with the longer "tongue" is also "fatter" than the shorter one..
HairyMcbiker
All Star
Fixes: 21
Interesting
Checking with a steel rule, the short one is over 5mm so apparently the correct length, the longer one is ~8mm. So must be my phone breaking the rule with the socket too far inside the edge.
Just looked at the phone connector, it is recessed about 2mm inside the case.
HairyMcbiker
All Star
Fixes: 21
OK scalpel wouldn't hack it, but my trusty rotary tool did.
Took a bit much off, but it now works fine. Might try adding a small bit of hot glue to fix it up.
Anotherone
Champion
Fixes: 21
Ha, now very interesting that I should come across this. I bought one of those 90° ones a couple of weeks ago and it's a tidy fit to the two phones I need it to fit.
Unlike @w23 (thanks for the drawing and dimensions) I did get my micrometer out Tongue - only because he mentioned it, otherwise I'd have used a ruler Wink and it measures 5.5mm.
Now the power adapter and USB lead that came with my cheapo Samsung phone are in fact 5.4mm, and likewise the one that came with the cheapo LG phone.
The plug on the 90° lead I bought being visibly (with my glasses on) that tiny bit longer. I did a comparison with 2 other USB leads I've got, one was 7.5mm and the other was 8mm (the cheap £1 job).
Which phone is that you have HM? (note to self, don't buy one).
nanotm
stick to buying the cheap stuff, they break more often but tend to work across more gear Tongue
HairyMcbiker
All Star
Fixes: 21
My new phone is a Homtom HT7 pro. web site
Android 5.1, 5.5",  2/16Gb, 4G dual sim.
Battery life is poor, but that is normal for a China phone.
Anotherone
Champion
Fixes: 21
@HairyMcbiker unfortunately the link is broken, not sure why I've a funny feeling when you are creating links you have to make sure the www is on the front (when needed) eg. there are sites that aren't www like this place, also have to be sure the http:// (or https://) is also there but it should prompt you for http but not sure about https.
HairyMcbiker
All Star
Fixes: 21
I used the include link button not hard coded it. So it needs a full url eh? OK will edit it.
It accepted the url I had put in homtom.cc, but now has the full url.
twocvbloke
That blue cable looks just like the cable I bought for my blue PS4 pad (I use it on my PC, got used to my white pad on my PS4 before I sold it so had to have another pad), the Micro-B end stopped working a week after I got the damned thing but the cable was too nice to throw out, so I just replaced the plug with some DIY solder-on plugs off ebay, oddly worked out cheaper than another new cable!! Grin
Fiddly as heck to solder though...
HairyMcbiker
All Star
Fixes: 21
Yeah I have a few spare plugs but they are so small I need a magnifying glass to see the contacts!
