Mesh system fttc help please.
Jeffwd1
Hi any help/advice greatly appreciated.
We have fttc, there is a TP link media system that connects Ethernet to each room, currently using an Archer VR2800 router.
I would like to install a mesh system to connect to the media system, then add mesh devices via Ethernet in appropriate rooms.
Is this possible with all mesh systems, do I use the Archer in bridge mode or Hub2?
Cheers
Jeff.
2 REPLIES 2
Re: Mesh system fttc help please.
@Jeffwd1 welcome to the community
What is the TP link media system you refer to? model number would be helpful.
My thinking is you are referring to a switch which needs to support 1000Mbps for best speeds
Some mesh system do support ethernet backhual connection rather than wireless, you would need to check the specification.
For simplicity I would use the Hub two in bridge mode, the change is made in >Advanced Settings >Broadband >Bridging
Set to YES.
You connect the master mesh units WAN port to LAN 1,2 or 3 of the Hub Two, NOT the Hubs WAN port
Jeffwd1
Hi Dan, thank you for your help, the media system is.
TP-link
TL-SG1016D
16-Port Gigabit Switch.
Cheers
Jeff.
