Mermory stick formatting advice please
- Mermory stick formatting advice please
14-04-2015 3:46 PM
As it will be used on Windows Vista Home Premium files... would I be correct in assuming that I need to format it with NTFS ?
Re: Mermory stick foramtting advice please
14-04-2015 3:48 PM
one thing to check - since I don't know the answer - will Linux read NTFS in case you hit a problem
14-04-2015 4:25 PM
14-04-2015 4:36 PM
Just thought I'd mention it.
14-04-2015 4:42 PM
Linux will read NTFS but I would suggest that USB sticks are best formatted FAT32 since everything will read that. You never know you might want to connect it to say a Car audio system and that's going to struggle with NTFS!!
Quote one thing to check - since I don't know the answer - will Linux read NTFS in case you hit a problem
14-04-2015 4:59 PM
brill forumites that you are !
Just to confirm.... I have also made the memory stick Linux Mint bootable, and during the process, it says the memory stick should be formatted in FAT16 or FAT32 format....otherwise it wont work...
rebooted and it sure does...
Re: Mermory stick formatting advice please
14-04-2015 7:18 PM
15-04-2015 8:45 AM
solves the 4GB limit and exFAT works on Windows, Linux and Mac, so no issues with cross compatibility.
15-04-2015 9:56 AM
I bought a 64Gb sd card and it came pre-formatted in it. Same it was a fake though. Fighting to get my money refunded now. Got it on Alibaba which CLAIMS that if you are unhappy you get a full refund, so far still waiting. (Ran f3 & h2test on it and it failed, so not scamming them.)
15-04-2015 10:05 AM
15-04-2015 11:57 AM
solves any comparability issues (and negates the need to install NTFS plug-ins on the mac).
16-04-2015 6:06 PM
16-04-2015 8:42 PM
16-04-2015 8:43 PM
My multiboot usb stick is able to boot all os's I stick on it with exfat.
using the easy2boot software (there is also a formatter tool).
rufus is one such tool
rmprepusb is more advanced and on the easy2boot website
17-04-2015 7:52 AM
Quote from: vilefoxdemonofdoom exFAT has got to be a case of flogging a dead horse.
care to back that up with any sensible theory?
or are you just a muppet with more time on your hands than you know what to do with.
