Memory upgrading.
- Re: Memory upgrading.
Memory upgrading.
27-01-2012 10:43 AM
I'm thinking of upgrading my PC memory from 4Gb to 8Gb; sometimes space becomes a bit of a premium. There is a spare DDR channel available. I seem to remember from somewhere in the dim distant past that sometimes fitting additional (but identical make, type and size) memory sticks from a completely different manufacturing batch causes problems, because the chips are bound to have slightly different characteristics.
Anyone had experience of this? Is it better to buy a completely new set of 8Gb sticks rather than add another 4Gb?
5 REPLIES 5
27-01-2012 10:51 AM
The problem usually comes when the board uses memory in dual channel mode
http://www.crucial.com/kb/answer.aspx?qid=3751&click=true
Also check with your motherboard as it may just not be happy with mismatched memory sizes - you don't say what you have a present
It is worth doing a search to see if there are any reported problems when running with all memory slots full and whether you need a bios upgrade
27-01-2012 11:01 AM
Thanks Jim. It's 2x2Gb. I've already sussed that a BIOS update will be needed. I think I shall give an additional 2x2Gb a try.
How's the Olympic preps going down your end?
27-01-2012 11:03 AM
Flaming disaster http://www.highways.gov.uk/roads/projects/30554.aspx
27-01-2012 11:33 AM
Quote 'm thinking of upgrading my PC memory from 4Gb to 8Gb
Bear in mind that you'll need to be running a 64Bit OS to make use of more than 4Gb.
27-01-2012 12:19 PM
Yes... I am.
