Memory Upgrade
morgan2476
Memory Upgrade
Hi folks
I plan to upgrade memory it seems I have the choice of pc2700 and pc3200 what is the diference and what should I go for
Donald
Re: Memory Upgrade
The cheapest.
Chances are they're both the same price and probably only 3200 is available.
It's all compatible so if the motherboard takes either it's irrelevant.
The speed difference on a PC of the vintage that takes that memory is trivial. The added memory will make much much more difference just by existing.
Rich
Re: Memory Upgrade
PC2700 = DDR333
PC3200 = DDR400
If your CPU is using a 333MHz FSB, use either type.
If your CPU is using a 400MHz FSB, use PC3200.
That said, if you're adding rather than replacing, it is better to match the stuff already installed, if possible.
Richard.
Re: Memory Upgrade
the higher the number the faster the memory.
crucial.com has a handy tool to tell you what your computer is rated at and how much ram you can put in it.  if you run windows, you can download their scanning tool.  i've used it several times to determine what my various machines needed.
if you run linux, you have to go through a few more steps and you may find that only firefox renders the page accurately.
Re: Memory Upgrade
It dosnt really matter, but its best to match. The 3200 will run at 2700 if it needs to. As HPSauce says, its the amount of memory in this case, thats more important, rather than the speed it runs at!!
Rich
Re: Memory Upgrade
Quote from: penfold
unless you try to run PC2700 at PC3200 speed - that's just asking for a blue screen!
Re: Memory Upgrade
Quote from: morgan2476
Which presumes the motherboard supports either, and this is almost always automatic.
The tone of the question doesn't suggest a rampant overclocker... Crazy (they wouldn't need to ask)
morgan2476
Re: Memory Upgrade
I currently have a socket A motherboard which i am happy with, what I was looking to do was to upgrade processor and memory.
morgan2476
Re: Memory Upgrade
What is the difference between high and low density memory?
Re: Memory Upgrade
To be honest, I wouldn't, certainly not processor.
Processor upgrades are riskier than memory, and you really need to know what you're doing.
All due respect, but your initial question suggests that you probably don't know enough.  Wink
