Mcafee cannot install
- Re: Mcafee cannot install
21-05-2016 9:44 AM
When installing Mcafee I get and error message that mfehidin.exe has crashed and addition messages re not able to install. See attached file.
I have searched the problem and there are a huge number of confusing and misleading reccomendations re mfehidin.exe.
Any assistance would be appreciated.
21-05-2016 11:19 AM
There are plenty of other free AV about ,, Macafee is not one of the best
21-05-2016 11:26 AM
know that but if they provide a product you would think it would install without issue, I think it's because I had a subscription with McAfee before but uninstalled it recently, there may be some hidden file or registry entry that is stopping it installing as it is a free version.
21-05-2016 11:41 AM
PN also used to provide a Fix it software for Broadband , but it never worked correctly
When you uninstall via windows yes it does leave some rubbish around , so i always use Revo uninstaller which clears the registry http://www.revouninstaller.com/revo_uninstaller_free_download.html make sure you get the freeware version lower down on page
21-05-2016 11:57 AM
Mcafee is rubbish anyway,something i would not use ever.
21-05-2016 4:54 PM
"What is Mfehidin.exe and How to Fix It? Virus or Safe? - Solvusoft" -- that sort of thing.
Now, in picture 3 it says you need an update - did you go get the update?
MvAfee's website lists three known issues with that part - most caused by "trustedInstaller", microshatfs monopoly control device *cough* sorry "protection device".
The also list the patches that corrected the issues.
https://kc.mcafee.com/corporate/index?page=content&id=KB70393
As an aside - I REALLY don't like the mechanics of this forum... having to manually enter BR for line breaks when every other forum I've been on inserts them for you when you press enter!
I don't think I'll be spending much time here... too backward!
21-05-2016 10:44 PM
Welcome to PN,s ,, NEW and IMPROVED forum
22-05-2016 10:21 AM
Yeah,right.
